Everything in its place and a place for everything (well nearly). This UJK T-LOC Systainer case comes with a pre-cut good quality internal foam insert ready to take the parts of your UJK Parf Mk II Guide System or Parf Mk I System, with the exception of the Parf Sticks. The T-LOC connects to others from UJK range as well as Festool and other brands that use T-LOC SYS2 and SYS3 cases as part of a complete storage solution.
T-LOC Systainer case 396mm long x 296mm wide x 105mm high.
Intended Use Storage case for use with the Parf Guide System.
Web Attribute Set Organiser Cases
EAN Barcode 5052511127559
