This is an ideal saw for pruning small and larger fruit trees or trimming thick branches in unruly hedges. The long blade with its diamond ground teeth cuts like the proverbial hot knife. The saw cuts on both the pull and push stroke, this action produces fast and clean results. When pruning a live tree, a cleanly cut surface will heal much quicker. The saw’s sheath features a belt clip, its design allows you a choice of right or left handed use. The pistol-grip handle has a soft grip for comfort and offers better control. The blade has impulse-hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The 270mm long blade is replaceable; it is 0.70mm thick with a 2.4mm pitch.
Zet Saw
Z-Saw Japanese Fixed Pruning Saw in Sheath - 270mm
| Blade Thickness | 0.70 mm |
| Web Attribute Set | Japanese Handsaws |
| EAN Barcode | 5052511094363 |
