This is an ideal saw for pruning trees or trimming rogue branches. The longer blade and universal teeth make this a good choice for cutting sawn timber, framing and roofing. The diamond ground teeth work like a proverbial hot knife, producing fast results. The die-cast aluminium handle has an elastomer grip, giving you better control and a more secure grip. When not in use the blade folds into the handle protecting the teeth. Folded, the saw fits easily into a toolbox or a deep pocket. The blade locks in position when open with a choice of two positions for cutting convenience. The blade is 240mm long, 1.0mm thick with a 1.28mm kerf and a 3.2mm pitch.
Tools from Japan
Z-Saw Japanese Folding Pruning Saw - 240mm
| Blade Thickness | 1.00 mm |
| Web Attribute Set | Japanese Handsaws |
| EAN Barcode | 5052511094349 |
