ROJEK PK 320A 3.2m Panel Saw & Overhead Guard 230V
A 0% interest offer you can use again and again.
PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Enquire - contact us for a personalised quote
- Well designed big capacity panel saw with cast iron table
- Includes overhead crown guard and ripping stop
- Scoring blade for splinter-free cuts
The PK320A Panel Saw is a large capacity machine. It offers any demanding professional workshop a high degree of accuracy coupled with ease of use and reliability. Separate motors drive the main blade and the scoring blade. The motors, the rise and fall and tilt mechanisms are mounted in a robust cast iron housing guaranteeing solidity with smooth and precise adjustments. The PK320A comes fitted with a very well designed sliding table. The sliding table is mounted on round chrome-vanadium steel bars and runs exceptionally smoothly.
This ready to buy package includes a number of beneficial accessories: an overhead crown guard for improved extraction and better visibility of the workpiece; a ripping stop to aid with cutting waney edge timber; and a push handle for the sliding table, giving increased control. This machine is also supplied with a single phase motor, ideal for smaller professional workshops.
The PK320A is a high quality European made machine, built to last. Our specialist consultants will be happy to discuss the ROJEK range with you; email [email protected] or call 03332 406406.
Blade Diameter | 315 mm |
Blade RPM | 4,400 rpm |
Blade Tilt | 0° to 45° |
Bore Size | 30 mm |
Dust Extraction Outlet | 100 mm & 60 mm |
EAN Barcode | 5052511132584 |
Max Depth of Cut @ 45º | 70 mm |
Max Depth of Cut @ 90º | 100 mm |
Min Extraction Airflow Required | 1,400 m³/hr |
Nett Weight | 515 kg |
Overall L x W x H | 3,575 mm x 3,360 mm x 1,150 mm |
Rating | Trade/Professional |
Scoring Blade Bore | 20 mm |
Scoring Blade Diameter | 120 mm |
Sliding Table Dimensions | 2,800 mm x 360 mm |
Sliding Table Stroke | 2,800 mm |
Sound Power Level LwA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 73 dB(A) [3.0 dB] |
Table Height | 890 mm |
Table Size | 955 mm x 400 mm |
This product is classified as a Large Delivery product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact you upon completion of your order to discuss carrier options and arrange a delivery date to suit you.
- UK Mainland - £70
- UK Remote & Offshore* - charge advised in basket
