Tite-Fix Screw-Tite Made For Trade Organiser - Pack of 1,300
110599
From £49.98 £41.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Buy 5 for £47.48 £39.57 each and save 5%
  • Buy 10 for £44.99 £37.49 each and save 10%
  • Buy 15 for £42.48 £35.40 each and save 15%
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 16th May
  • Tri-lock TS Threadform for an immediate start
  • Tri-lock shank means there is 25% less insertion torque
  • High-quality pozi, multipurpose screws
  • For use in a large range of materials without the need to pilot hole in most cases
  • Double countersunk head ensures a clean, flush finish
Find the screw you need quickly and efficiently with this handy organiser case, containing a variety of different Screw-Tite pozi screws so you have everything you need at the ready.
Tite-Fix Screw-Tite pozi screws are the fixing for you if you want a guaranteed, high-quality finish. These multipurpose, advanced screws have a unique Tri-Lock TS Threadform which joins together the benefits of a single thread and twin thread in one screw. You will get a balanced, immediate start with a fast insertion leaving you with a firm fix. The tri-lock shank ensures there is 25% less insertion torque, so your timber will not receive any damage. Screw-Tite screws can be driven into a large range of materials including hardwood, softwood, masonry, sheet steel, plastic and more without the need to drill pilot holes in most cases. The double-countersunk head means you will achieve a clean, flush finish every time. These screws have a PZ recess.
Please note, a pilot hole is needed when using masonry.
Pack contains:
200 - 3.5 x 30mm
200 - 4.0 x 40mm
200 - 4.0 x 50mm
200 - 5.0 x 50mm
100 - 4.0 x 60mm
100 - 4.0 x 70mm
100 - 5.0 x 70mm
100 - 5.0 x 80mm
100 - 5.0 x 100mm
