Tite-Fix Screw-Tite Trade Pack - Pack of 750
110600
From £29.98 £24.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Buy 5 for £28.48 £23.73 each and save 5%
  • Buy 10 for £26.98 £22.48 each and save 10%
  • Buy 15 for £25.48 £21.23 each and save 15%
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 28th Mar
  • Tri-lock TS Threadform for an immediate start
  • Tri-lock shank means there is 25% less insertion torque
  • High-quality pozi, multipurpose screw
  • For use in a large range of materials without the need to pilot hole in most cases
  • Double countersunk head ensures a clean, flush finish
Ensure you have everything you need with this Trade Pack that includes a variety of screw sizes, perfect for if you need more than one size.
Tite-Fix Screw-Tite pozi screws are the fixing for you if you want a guaranteed, high-quality finish. These multipurpose, advanced screws have a unique Tri-Lock TS Threadform which joins together the benefits of a single thread and twin thread in one screw. You will get a balanced, immediate start with a fast insertion leaving you with a firm fix. The tri-lock shank ensures there is 25% less insertion torque, so your timber will not receive any damage. Screw-Tite screws can be driven into a large range of materials including hardwood, softwood, masonry, sheet steel, plastic and more without the need to drill pilot holes in most cases. The double-countersunk head means you will achieve a clean, flush finish every time. These screws have a PZ recess.
Please note, a pilot hole is needed when using masonry.
Pack contains:
100 - 3.5 x 20mm
100 - 4.0 x 25mm
100 - 4.0 x 30mm
100 - 4.0 x 40mm
100 - 4.0 x 50mm
50 - 5.0 x 60mm
50 - 5.0 x 70mm
50 - 5.0 x 80mm
50 - 5.0 x 90mm
50 - 5.0 x 100mm
