UJK Motor Mount for Router Lift
- Direct replacement for the UJK Motor Mount
- Securely connects the UJK Router Motor to the Router Lift
- Precision-engineered for accurate alignment and smooth operation
- Robust construction for durability and long-term performance
- British made
The UJK Motor Mount for Router Lift is a precision-engineered, British-made component designed to ensure a secure and accurate connection between the UJK Router Motor (SKU 114370) and the UJK Router Lift (SKU 502701).
As a direct replacement for the original UJK Motor Mount, it offers a straightforward solution for maintaining or restoring the performance of your routing setup. Manufactured to exacting standards, this robust mount provides precise alignment between the motor and lift, which is essential for smooth operation, reduced vibration and consistent cutting accuracy. Its solid construction delivers long-term reliability in demanding workshop environments, making it an essential component for anyone looking to keep their router lift system performing at its best.
| EAN Barcode | 5052511141067 |
