Axminster Workshop 10 Piece Cobalt/HSS Drill Bit Set
300284
300284
- M35 precision ground high speed steel
- For use on alloy, hardened steels, cast iron, titanium and more
- Set of 10 drills, sizes range from 1mm to 10mm x 1mm steps
Axminster Workshop 13 Piece High Speed Steel Ground Drill Bit SetFrom £7.28 £6.07
Show more
Show less
Precision ground from M35 high speed steel bars with 5% cobalt achieving a hardness of some 66-67 Rockwell. Intended for use on alloy and hardened steels, cast iron, titanium and many other really tough, hard-to-drill materials such as stainless steel. Sizes range from 1-10mm x 1mm.
EAN Barcode | 5052511011001 |
