Axminster Workshop 170 Piece High Speed Steel Ground Drill Bit Set
110261
110261
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
- Solid ground HSS drill bits, TiN coated for extra durability
- 10 of each 1mm to 8mm, x 0.5mm
- 5 of each 8.5mm to 10mm x 0.5mm
- You can never have too many drill bits
- Strong case keeps them where you can find them
Show more
Show less
One of the best value for money items Axminster has so far offered. Contained within a strong steel case, more importantly fitted with a strong sectioned liner, is just about every standard metric drill bit you're ever likely to need. Ground for accuracy from high speed steel and TiN coated for extra durability, there are 10 of each size, 1mm to 8mm, in 0.5mm steps, then 5 of each size 8.5mm to 10mm by 0.5mm. Making it highly unlikely you'll have to make do with a blunt or broken bit again.
#AxminsterTools
