Arbortech Turbo Scraper
- Rapid freehand wood scraping
- Ultra-smooth, scratch-free finish
- Cuts at a negative angle to prevent digging into wood
- Distinctive design provides real-time visibility while carving
- Durable carbide teeth ensuring long blade life even in hardwoods
The Arbortech TURBO Scraperâ„¢ is the ideal choice for woodworking projects that demand precision and accuracy
Think of this powerful disc as a turbocharged upgrade to a conventional hand scraper. Specifically engineered to cut at a negative angle, it minimises tear-out and chipping. When applied with pressure, it gently scrapes wood, resulting in a smooth, scratch-free finish. Its distinctive design allows you to see your work clearly, meaning you can monitor carving progress and achieve exceptional precision - even on delicate details. Unlike traditional burr discs, the TURBO Scraperâ„¢ remains unclogged, ensuring impeccable accuracy. Cleaning becomes effortless, eliminating the need for an array of tools.
The TURBO Scraper is slower at removing timber compared to the TURBO Plane and Industrial Woodcarver. This intentional design feature provides professionals with superior control over delicate tasks but also makes it by far the most beginner-friendly. By merely adjusting the pressure you carve as much or as little as you like and, should you get any, burn marks are quickly and easily removed. The profile is perfect for doing big wide curves, ideal for chair seats and is great for spoon makers when used in a vertical position. Those looking to shape internal and external profiles with speed and accuracy, such as high-end furniture and instrument makers, will also find this blade hugely beneficial.
The disc is made from forged aluminium which offers a high strength-to-weight ratio and durability. The three durable tungsten carbide blades hold their edge well and can be rotated and replaced for optimum performance and longevity. Compatible with the Power Carving Unitâ„¢ or any standard 100mm (4") or 115mm (4 1/2") grinder. When using the TURBO Scraper, ensure your angle grinder has an auxiliary handle for better balance, control, and visibility during carving.
Craftsmanship meets ease with the TURBO Scraperâ„¢!
