Axminster Workshop 6 Piece Tapered Drill & Countersink Bit Set
107225
107225
From £26.28 £21.90
  5. Half Star
39 Reviews
In Stock - Ready to dispatch
  • 6 piece set; 1/4" hex shank drill, countersink and counterbore
  • Drill bit adjustable, tapered hole ensures secure screw fit
  • Adjustable stop collars for couterbore or just countersink
  • Set comprises: 2.8mm, 3.6mm, 4.4mm, 4.8mm, 5.6mm and 6.4mm drill bits
Drill, countersink or counterbore all in one operation to a high degree of accuracy. This six piece drill/countersink/counterbore features 1/4" hex shanked bits for use in a drill chuck or quick change holder. The length of the drill bit is adjustable. The set comes with two depth stop collars for setting the depth of the counterbore if required. The tapered drill bit cuts perfect seating for a split-free and secure screw fixing. Set comprises: 2.8mm, 3.6mm, 4.4mm, 4.8mm, 5.6mm and 6.4mm diameter drill bits.
4.30 39
