Axminster Professional 1.0-13 x 0.5mm TiN Coated HSS Drill Bit Set 25 Pce
504843
504843
From £103.48 £86.23
  5. Half Star
2 Reviews
Low Stock - Ready to dispatch
  • Good general drilling quality on a wide range of materials
  • Made from HSS to DIN 388, TiN coating for longer tool life
  • Sizes 1mm to 13mm in 0.5mm increments
  • Supplied in a sturdy ABS or metal case
  • Able to drill in steel, cast steel alloyed and non-alloyed, grey cast iron, graphite and malleable cast iron
This 25 piece jobber drill bit set has a quality TiN coating which helps the bit last longer. The design includes a unique multi-layer coating, split point and modified web construction. These aspects allow you a wider range of applications, reduced thrust requirements and increase rigidity. Made to DIN 338, these drills are high quality HSS, they can be used on a wide range materials including cast steel alloyed and non-alloyed, grey cast iron, graphite, malleable cast iron and woods. Sizes from 1-13mm in 0.5mm increments.
4.50 2
