Axminster APF 10 Evolution® Powered Respirator
- Positive pressure powered respirator offering a cool, comfortable supply of filtered air
- Air is blown over your face and away from your airways unlike negative pressure powered respirators
- Li-ion battery gives 8 hours run time
Customers Also Bought
This positive pressure powered respirator eliminates the drawbacks encountered with standard negative pressure face masks. The motor unit blows filtered air down over your face at a rate of 160L/min. Fatigue caused by having to suck through a filter is no longer a problem; breathing is normal and comfortable. The air exiting around the sides and bottom of the mask is at slightly higher pressure than that outside, so forms a most effective seal. Beards are not a problem. If you wear glasses, these will not fog or mist up as you breathe out.
With the motor and filters mounted on the peak of the bump cap and the battery at the rear, the balance of the APF 10 Evolution® unit is excellent. Combined with the low overall weight (680g), it is very comfortable. The Li-Ion batteries give you a run time of 8 hours on a full charge. The filters are easy to inspect and replace. The bump cap’s outer cover is removable for washing. The unit provides respiratory protection to EN12941:1998 + A2:2008 TH1P. The bump cap gives head protection to EN812. The clear visor gives you a wide field of vision along with impact protection to EN.166.B.1.
Supplied with an 8-hour battery, two filters, a flow-rate meter, micro USB charge lead, and complete instructions all within a strong storage box. To extend the life of your respirator we recommend the APF 10 Evolution® Powered Respirator Pre-Filter Pad (Pkt 10) (101850) and the APF 10 Evolution® Powered Respirator Peel Off Visor Overlay (Pkt 10) (101844).
Respiratory protective equipment (RPE) should not be used as the only means of control as it should complement other control measures such as a dust extraction system. Each RPE type and class is categorised by an assigned protection factor (APF). The APF is a number rating that indicates how much protection that RPE is capable of providing. For example, RPE with an APF of 10 will reduce the wearer’s exposure by at least a factor of 10 if used properly, or, to put it another way, the wearer will only breathe in one-tenth or less of the amount of substance present in the air.
Please note: To reduce any possibility of premature motor failure/fan breaking it is imperative that the mask and filters are maintained, replaced and cleaned on a very regular basis.
When choosing respiratory protection, please ensure this is a suitable level of protection for the wood you are working with.
N.B. Evolution® is a registered trade mark of JSP Ltd, used under licence by Axminster Tool Centre Ltd.
We can only send to UK, EU (excluding Germany) Norway, Iceland & Switzerland.
Now supplied with a micro USB charge lead that plugs directly into the battery. A mains plug for the lead is not supplied.
- Constant clean airflow at 160L/min eliminates breathing resistance
- Respiratory protection to EN12941:1998 + A2:2008 TH1P. Assigned Protection Factor 10 (UK classification) equivalent to an EN149 FFP2.
- Bump cap provides head protection to EN812
- Full face visor for clear vision and impact protection to EN.166.B.1
- Lightweight (680g) and well balanced, excellent comfort
- Made in Britain
- To reduce any possibility of premature motor failure/fan breaking it is imperative that the mask and filters are maintained, replaced and cleaned on a very regular basis
