The CT-502H is a purpose-built extractor for metal dusts. It has a unique air flow system that separates out the dust from the airflow to allow the various weights of metal particles to fall into either the large primary collection bin or a smaller secondary bin. A powerful 1.125kW 230V 1ph motor creates up to 1,360 m³/hr airflow through a choice of either a 150mm inlet or a pair of 100mm inlets. The impeller fan is an aluminium casting with efficient curved blades. The aluminium impeller construction prevents impact sparking from metal particles.The machine is heavily built and is mounted on castors for easy mobility. A large grab handle is fitted to make this an easy task. The three stage filters are mounted inside a drop down door, also giving access to the secondary collection bin. The main collection bin is mounted on rollers and is easily accessed through a large door. This machine would be a perfect partner for a metal grinding or linishing machines, suitable to use with ferrous metals, keeping your workshop and the operator clean. Heat resistant ducting hose is recommended, please see accessories.
Machine Classification
