Axminster Workshop Grinding Wheel 150 x 40 x 12.7mm
107328
From £22.48 £18.73
  5. Half Star
4 Reviews
In Stock - Ready to dispatch
  • Sharpen high carbon tool steels and HSS tools
  • Cooler cutting, less chance of overheating the tool
  • Fast cutting, medium hard vitrified bond 80g aluminium oxide
  • 40mm wide, 150mm diameter, 12.7mm (1/2") bore
This replacement aluminium oxide grinding wheel for the Axminster Workshop AW1502WSG Wide Stone Grinder will of course fit many other machines using stones with the same dimensions. White grindstones have a slightly softer bond compared to grey grinding wheels. White Aluminium Oxide grinding wheels are a preferred choice for general tool sharpening of high carbon and HSS tools. White wheels cut much cooler with far less tendency to overheat a tool’s edge. They are friable and cut freely offering a fast result and clean finish. This stone is 40mm wide, 80 grit for fast, fine results and 150mm diameter with a 12.7mm (1/2") bore.
4.50 4
