Axminster Engineer Series Machine Coolant Pump System
104941
From £204.78 £170.65
5 Reviews
In Stock - Ready to dispatch
  • Suitable for mills, drills, lathes and metal cutting bandsaws
  • Compact design for convenient positioning in small space
  • Flexible delivery hose with shut-off valve to control flow rate
  • 9 litre coolant tank with internal baffle to control sediment
  • Swarf sieve in coolant return to collect waste
  • 95W 230V motor provides up to 24 l/min flow
  • Fitted with in-line switch, cable and plug
The Axminster Machine Coolant System consists of a 9 litre tank and a 95W 230V electric pump. Supplied as a complete kit, it also includes a flexible discharge hose and nozzle, 2m delivery hose pipe, 1m return hose, shut off valve and mounting bracket and fixings.
The unit is easy to retrofit to an existing machine. It is relatively small, so should not present any problems finding a convenient location. It will fit inside a lathe cabinet, under the bench, wherever you like, bear in mind you will need to top it up and clean it out occasionally.
The Axminster Machine Coolant Pump System is suitable for use with drilling/milling machines, small lathes, metal cutting bandsaws, etc. The waste sieve filters swarf and is easy to remove and clean. The tank has a mid baffle, which prevents sediment reaching the pump unit.
Supplied with an inline switch, cable and fitted with 13A BS plug. 390mm long, 270mm deep and 320mm high.
5.00 5
