Axminster Workshop Non Stick Dowel & Biscuit Glue Brush
107545
From £6.88 £5.73
6 Reviews
  • Apply glue quickly and easily exactly where it’s needed
  • Use with PVA etc, equally effective with most polyurethane glues
  • Rinse with soap and water or peel off when dry, reuseable over and over
This is a pack of two reusable glue applicators. Ever had trouble getting glue into slots and dowel holes. These double-ended silicone rubber applicators solve the problem. The dowel tip allows you to work the glue into the dowel hole. The biscuit tip tapers to a thin flexible flat end allowing you to apply glue into a biscuit slot with ease. These applicators work with most wood glues, PVA or polyurethane. To clean, either wash with soap and water or let the glue dry and then peel it off, which is more fun.
4.80 6
