Axminster Workshop Engineer's Square - 50mm
105417
From £6.88 £5.73
  5. Half Star
19 Reviews
In Stock - Ready to dispatch
  • 50mm blade; pocket sized accuracy
  • Great for woodworking, metalworking, modelling
  • Four 90° angles, all faces square to all edges
  • Stainless steel blade triple riveted for permanent accuracy
  • All faces ground with polished finish
  • Conforms to DIN875/II, guaranteed square
Keep this handy 50mm grade II engineer’s square in your apron pocket, where it will always be ready for action.
This neat measuring tool is perfect for small-scale projects and for marking and checking squares in tight spots. Small in size but by no means any less accurate, it conforms to DIN875/II and is guaranteed square. It has four 90° angles: internal and external, outside blade to inside stock and inside blade to outside stock. The hardened and tempered blade and steel stock are ground and polished.
This is a must-have tool for woodworkers, engineers and model makers.
4.40 19
