Axminster Workshop Roller & Bracket Set - 400mm
103701
From £29.88 £24.90
In Stock
  • 57mm dia x 400mm long, smooth free running roller
  • Smooth, hard chrome plated, will not mark work
  • Provides material support up to 80kg load
  • Create custom designed roller support stands
  • Easy to fix to a bench or sawhorse
This large roller measures 400mm long x 57mm diameter. It has a ball race bearing at either end to ensure smooth free running. The roller and bracket set is an easy solution when looking for extra material support for a saw bench or mitre saw for instance. The spring-loaded axle makes it easy to remove the roller from the bracket. The strong steel bracket has mounting holes for screwing to a bench top or a sawhorse etc. The roller then clips back into the bracket. The large roller has a load capacity of 80kg. With this roller and bracket, you can build and design your own roller stand or fix several onto a workbench for heavy-duty jobs. Smooth rolling, the heavy-duty steel roller is 57mm diameter by 400mm long, overall the unit is 66mm high and 444mm long.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.80 12
