Axminster Workshop Blade Reducing Bushes
AX23230
AX23230
- 30mm outside diameter
- Standard 2mm thick
- Range of bore sizes available
Show more
Show less
Saw blade reducing bushes all with a standard 30mm outside diameter. They are 2mm thick (please check your blade's plate thickness) and available in a range of bore sizes. N.B. Please check that your saws blade clamping discs are larger than 30mm in diameter, otherwise they will not clamp the blade.
British Made
