Axminster Professional Universal Clamp 10-48mm
- Problem-solving clamps for edging, carcasses, T-joints, corner joints, frames,
- Easy to position and tighten, sold singly
- Spring-loaded, eccentric cams for instant grip, range 10 to 48mm, depth 80mm
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
See the entire rangeThe more tasks a tool can perform the greater the value. These universal clamps help in tricky situations that usually require more specialised clamping solutions. The one-sided frame design solves problems when gluing edging, carcasses, T-joints, corner joints, frames, etc. You can apply and tighten them with one hand, leaving your other hand free to hold the work in position.
The spring-loaded, eccentric cams that form the jaws have a high-friction resilient rubber over-mould. This ensures a firm non-slip grip and prevents damage to the workpiece. As you apply pressure with the handle, the cam jaw grips ever tighter for an ever firmer hold. A swivelling plastic end cap on the screw protects the work.
Sold singly.
Grip range 10mm to 48mm, jaw depth 80mm.
EAN Barcode | 5052511109647 |
