This is a miniature multi-fuction vice that can grip of shapes and types of materials. It can be clamped onto a workbench (max 40mm thick) or bolted permanently in place through the flange.
The jaws can swivel through 360° both vertically and horizontally, each function having a clamp for security. The jaws are of two types, the smaller 38mm being normal square edged for flat materials. The larger 62mm ones are cleverly designed. Able to hold flat, square or round materials, they are offset to the left to allow longer rods or bar material to be clamped. All jaws are hardened steel, ground for accuracy. A 50 x 20mm anvil is behind the rear jaw.
If you are looking for a small, do-anything vice for metalworking, it's here.
Lifetime Warranty*
If any vice fails due to a material or manufacturing defect it will be replaced free of charge.
