The 271 Router Plane is predominantly used for smoothing the bottom of grooves, dadoes and hinge recesses.
Small and compact
The blade is O1 steel, offering good edge retention and comes with a 25° bevel. Can be used in two positions; normal or the front position for stopped rebates.
Body
The body is ductile cast iron quality with an accurately ground base.
Adjustable fence
The adjustable fence controls the width of the rebate and is secured with guide rods for extra support.
Fine blade adjustment
Fine blade adjustment feature ensures precise depth of cut control.
As handy and useful as they come. The Axminster Workshop 271 small router plane is perfect for smoothing the bottom of grooves, dadoes and housings. These days it can be found most often cleaning out hinge or lock plate housings.
The cutter locks in position with a brass thumb screw, which has a screwdriver slot for an extra tweak. The cutter can be positioned either facing the open mouth which gives a better view for stopped grooves or inlay work. Alternatively, it can be used facing the closed mouth for better support in normal work. The base size is 105mm x 58mm, supplied with a 6.35mm cutter.
The cutter is O1 steel and requires honing before use. This router plane represents a good standard in traditional hand tools and great value.
