Axminster Workshop Tool Rest Upgrade Kit for 150mm Bench Grinders
108511
108511
- Give your grinder a real treat
- Easily fitted upgrade of the tool rests
- Strong, stable platform for grinding or tool sharpening
The standard tool rests supplied with lower priced bench grinders sometimes may not have all the functionality your project requires.
The Axminster Workshop Tool Rest Upgrade Kit offers a solid platform and two way adjustment; angle and in/out. A bracket bolts onto your grinder’s wheel cover with two bolts, replacing the one supplied with the grinder. The tool rest platform is a generous 108mm long by 45mm wide. A position indexed connection between the rest and the bracket guarantees rock solid angle setting. Once locked you have a firm stable platform for tool sharpening or general grinding.
