This handy 1/4" drive socket set comes complete with 12 bi-hex sockets made from hardened CrV steel, in a range of metris sixes 4 to 13mm. The Bahco SL25 set includes a quick-release compact reversible ratchet and a 10 piece 1/4" hex bit set along with a bit holder and 100mm extension bar. Ideal for the home, garage or workshop; the SL25 socket set is designed to give years of service. With this set in your toolbox you are well equipped to tackle any job involving nuts and bolts from M2 to M8.
Supplied in a sturdy, high-density polythene carry case with sponged lining that is labelled with the corresponding items for quick and easy identification.
Contents:
1 x 1/4" Reversible Quick-Release Ratchet
12 x Hex Sockets: 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 and 13mm
2 x Phillips Bits: PH2
2 x Hex Bits: 5mm and 6mm
6 x TORX Bits: TX10, TX15, TX20, TX25, TX30 and TX40
