Bahco Blades for 625 Pocket Carbide Scraper
- Solid tungsten carbide blades
- Available in four shapes
- 25mm triangular, 25mm circular 22mm teardrop or 20mm pear shaped
The blades are solid tungsten carbide, they will last up to one hundred times longer than conventional steel blades. Available in four shapes: 25mm triangular (giving three edges as well as three sharp points), 25mm circular, 22mm teardrop and 20mm pear shaped.
Model | 625 |
