Blum CLIP-TOP 170 deg. Hinge & Cruciform Mount Plate With Screws
717590
From £6.78 £5.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Buy 2 for £5.42 £4.52 each
  • Buy 10 for £4.75 £3.96 each
  • All metal nickel plated hinge with 170° opening
  • Spiral-tech depth adjustment
  • Tool-free door to cabinet assembly and removal
  • 3-dimensional adjustment (with mounting plate)
  • Height adjustment ± 2mm
  • Supplied with a Nickel plated zinc die-cast cruciform with pre-mounted screws
An all metal nickel plated hinge with 170° opening. It has Spiral-tech depth adjustment, tool-free door to cabinet assembly and removal plus 3-dimensional adjustment (with relevant mounting plate). Supplied with a nickel plated zinc die-cast cruciform with pre-mounted screws. Height adjustment ± 2mm.
Due to the nature of wide opening hinges such as the 170° CLIP-TOP, unavoidably a gap the diameter of a pencil can be inserted into the hinge. Therefore for child safety, we would advise where cabinets are accessible to children, safety latches should be fitted to avoid possible accidents.
