Space-Plug - Plug Adjustable Spacer Fixing
101160
Last Few
Special Price £8.40 £7.00
was £8.98 £7.48 Save £0.58 £0.48
7 Reviews
In Stock - Ready to dispatch
  • Simple, secure, neat and efficient, No need to mark out, you fix the unit in situ
  • A single unit requires only one Space-Plug and you only need drill one hole
  • Adjustable, replacing shims to bridge a stand-off for wider worktops
  • No more fiddly angle brackets when fixing kitchen base units
Space-Plug replaces the fiddly angle brackets, generally used to fix kitchen base units to a wall. Space-Plug is simple, secure, neat and by far the quickest and most efficient method available. A single kitchen unit requires only one Space-Plug and you only need drill one hole per unit. There’s no need to mark out, you fix the unit in situ. The fixing passes through the unit’s cross brace giving you a wide target area for fixing, avoiding bad plaster, pipework or lining up with wall studs etc. As the screw heads are inside the unit, even after the worktops go on, the cabinet is removable if necessary at any time in the future. Space-Plug is adjustable, thus replacing shims to bridge a stand-off for wider worktops.
XL size: 26mm x 21mm x 4mm - for gaps 45 to 80mm
Pack of 10 supplied with 6.0 x 200mm standard masonry drill bit
5.00 7
