Bosch 7 Piece ROBUSTLine CYL-9 MultiConstruction Drill Bit Set
- The universal drill bit for wood, masonry, ceramics, UPVC etc. No need for hammer mode in masonry!
- Suitable for wood, masonry, ceramics, UPVC and steel
- Diamond ground tungsten carbide tip
- Steep aggressive flute
- 5mm, 5.5mm, 6mm, 7mm, 8mm and 10mm
- All contained in a ROBUSTLine case
FISCH Quick Change System Masonry Drill Bit 8mmSpecial Price £1.99 £1.66 was £7.98 £6.65 Save £5.99 £4.99
For drilling into many different materials
A truly useful multi-purpose drill bit, designed for drilling into all materials including wood, masonry, ceramics, UPVC and even steel. This is achieved by diamond grinding the tungsten carbide tip to produce a multi-material ability. As with all cutting tools, it is essential to clear the waste material quickly and Bosch have achieved this by providing a steep aggressive flute. For strength and to withstand both rotary and all purpose drilling, the tungsten carbide tip is set and brazed into the drill head to precise criteria. All contained in a ROBUSTLine case: 5 x 85mm 5.5 x 85mm, 6 x 100mm, 6 x 100, 7 x 100mm and 8 x 120mm, 10 x 120mm.
