The design of the Bosch GCM 8 SDE puts ease of use at the top of the list. All aspects are considered, whether its adjustments, scope of materials or your working environment. The GCM 8 SDE Professional is compact and portable, weighing just 18.5kg. Variable speed control from 3,500 to 5,000rpm, allows you to cut a wide variety of materials from wood to metal or plastics. The saw comes with an SDS blade-locking nut. Blade changes are quick and simple, without any additional tools. The ability to change the saw blade so easily, to suit different materials, means work becomes more efficient and your blades last longer. The saw will cut bevels up to 47, and has indents at 22.5, 30 and 45 for ease of setting. The positioning of the bevel-locking lever on the right-hand side next to the bevel scale, simplifies the operation. Dust extraction takes place from two points, one above the blade through the guard and a second directly behind the blade. Fitted to the saw arm with a long aperture, this second point efficiently captures the debris. A depth-stop allows you to cut trenches or tenons. The GCM 8 SDE mitre saw includes a laser-projected cutting line, transport handle and side extensions on the left and right to support longer workpieces. Power output: 1,600 W
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
