Bosch Impact Control HSS Drill /Screwdriver Set
- High performance bit set in tough storage case
- Suitable for drill drivers, combi drills and impact drivers
- 26 x 1/4" hex impact bits, 8 x HSS drill bits, Q/ R Universal bit Holder
A 35 piece bit set designed for everyday use in impact drivers, combi drills and drill drivers. This set is perfect for situations requiring heavy-duty solutions.
The robust L-case contains twenty-six 1/4" hex screwdriver bits. The bits are extremely sturdy and long-lasting and especially suitable for use in impact drivers. They feature an extended, heat treated torsion zone to withstand the stress of high torque impact screwdriving. Eight HSS drill bits range from 3 to 8mm for drilling metal, plastics, wood etc. In addition, the set includes a 1/4" hex, quick release, universal bit holder.
Contents:
20 x 25mm 1/4" hex bits:
PH1 x 1, PH2 x 2, PH3 x 1, PZ2 x 3, PZ3 x 1, T15 x 1, T20 x 3, T25 x 3, T30 x 3, T40 x 1.
6 x 50mm 1/4" hex bits:
PH2 x 1, PZ2 x 1, T15 x 1, T20 x 1, T25 x 1, T30 x 1.
8 x HSS drill bits:
3mm x 1
4mm x 1
5mm x 2
6mm x 2
8mm x 2
1 x 1/4" hex, quick release, universal bit holder
