Bosch T119BO Jigsaw Blades Tight Curves in Wood
- 5-15mm softwood, plywood, chipboard and fibre board
- Suitable for tight curves
- Supplied in packs of 5
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Tight curves in 5-15mm softwood, plywood, chipboard and fibre board.
Blade Type | HCS, Ground and Set |
EAN Barcode | 3165140006941 |
Jigsaw Blade Length | 70 mm |
Jigsaw Blade Type | Tight Curves |
Max Cutting Depth | 15 mm |
Model | T119BO |
Tooth Pitch \ tpi | 2.00 mm \ 12.5 tpi |
