Bosch Semi Flexible Thin Grinding Discs
- Thin grinding disc only 3mm
- Less vibration and noise
- Ideal for curved surfaces
- Very smooth finish
- Cool grinding
These Bosch semi-flexible grinding discs are only 3mm in thickness - a big advantage, making them much easier to guide with less vibration and noise. Ideal for curved surfaces they will give a very smooth finish. Cooling ribs on the disc also help avoid colour markings on the material being ground. Available in 115mm or 125mm disc size.
Bore Size | 22 mm |
