Bosch T118EFS Jigsaw Blades Stainless Steel Cutting (Pkt 5)
701876
701876
From £10.88 £9.07
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Buy 10 for £9.79 £8.16 each
  • Buy 25 for £9.25 £7.71 each
  • Buy 50 for £8.71 £7.26 each
Low Stock - Ready to dispatch
  • Inox for stainless and other tough plate materials
  • 1.5mm - 4mm thickness
  • Bi-metal laser welded
  • Longlife and break resistant
  • Pack of 5
To cut a thickness of 1.5mm - 4mm stainless plate as well as other tough materials. The bi-metal laser welded combination of HSC and HSS gives longlife with a high break resistance, the HSS tooth has 8% cobalt making it very robust and more heat resistant than standard blades, the special milled and wavy set on the tooth strip for optimum cutting.
