Bushing Set for Measuring Cup Kit
- Enables you to accurately size your project
- Helps to speed up production
- Turn project kits with confidence
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
2 Piece Bushing Set you need to make the Measuring Cup Kit. The use of a pen mandrel with the correct bushing set makes turning project kits an easy process. Simply use the bushings on the mandrel as a reference to turn your blanks down to the correct diameter.
EAN Barcode | 743031897835 |
