This high performance blade delivers fast and accurate cuts in heavy-duty applications. It has a thin kerf, only 2.16mm, requiring far less power for a given cut. The kerf and 305mm diameter make it perfectly suited for cutting larger, thicker timber. The 7° hook angle adds to the smooth cutting action. With 78 tungsten teeth and an FZ/WZ grind (alternate bevel with a flat-topped tooth between each pair), this blade is a good choice for crosscutting, leaving a fine, clean finish on end grain. It has expansion slots for low vibration and reduced noise. The 30mm bore allows the blade to be used on a wide range of machines. Its Extreme Runtime design provides the blade with twice the working life span of more standard blades.
