Double-Sided Sanding Sponge
AX21071
AX21071
- Silicon Carbide grit
- Low density foam
- Enables a premium finish on profiled or flat surfaces
Show more
Show less
Silicon Carbide grain coated onto two sides of a low density foam to enable a premium finish on profiled or flat surfaces. Used wet or dry, they are excellent for preparation of surfaces prior to recoating. Available in 60, 100,180 and 220grits. Size approx 98 x 120 x 13mm.
Abrasive Backing | Foam |
Abrasive Material | Silicon Carbide |
