Dremel Keyless Quick Change Multi Chuck
104781
From £9.68 £8.07
Low Stock
  • Eliminates collet and wrench when changing accessories
  • Accepts all accessory bits with 0.8mm to 3.2mm shanks
  • Invaluable accessory; saves time
  • Fits most Dremel rotary multi-tools (see details)
The Dremel multi chuck (4486) allows the quick and easy changing of accessories without the use of collets. This miniature chuck accepts accessories with shank diameters between 0.8mm to 3.2mm. This invaluable accessory for Dremel rotary multi-tools avoids the need to change collets every time you switch an accessory with a different shank diameter.
To install the chuck first remove the standard collet holder and collet. Hold down the shaft-lock button, to prevent the main shaft from turning and screw on your new keyless chuck. Insert your chosen accessory and continue tightening until the chuck grips firmly. To change bits simply reverse the process.
Accepts all accessory bits with 0.8mm (1/32") to 3.2mm(1/8") shanks, use with Dremel rotary multi-tool models 4000, 400, 3000, 398, 395, 300, 285, 275, 200, 100, 8220, 8200, 800, 780, 770, 7700, 750, 8050. Also fits Dremel attachments 212, 225, and 575.
4.60 11
