Easy Wood Tools Ci0-NR Carbide Cutter - Round Negative Rake
- Fits the Full-Size Easy Finisher and Pro Easy Finisher.
- 15.6mm diameter, solid carbide
- Negative rake for acrylics, resin and very hard woods
- Optimum grade of carbide, long lasting cutting edge
- Proprietary grinding for the sharpest edge possible
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
The Ci0-NR negative rake round carbide tip is 15.6mm diameter. It fits the Full-Size Easy Finisher and Pro Easy Finisher.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
