Easy Wood Tools Ci1-R2 Carbide Cutter 2" Radius
109304
From £15.88 £13.23
2 Reviews
Low Stock - Ready to dispatch
  • Fits the Full-Size Easy Rougher and Pro Easy Rougher
  • 15mm square, solid carbide
  • Slightly curved edges minimise the risk of a catch
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci1-R2 solid carbide tip is 15mm square. It fits the Full-Size Easy Rougher and Pro Easy Rougher.
Each of the four edges is slightly curved with a radius of 2", hence the R2 suffix. The radius along the edge, minimises the risk of a catch from a sharp corner when moving the chisel from side-to-side.
​The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
5.00 2
