Easy Wood Tools Ci1-SQ Carbide Cutter Square
109250
From £15.88 £13.23
1 Review
Low Stock - Ready to dispatch
  • Fits the Full-Size Easy Rougher and Pro Easy Rougher
  • 15mm square, solid carbide
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci1 solid carbide tip is 15mm square. It fits the Full-Size Easy Rougher and Pro Easy Rougher
​The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
Easy Wood Tools® is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.
5.00 1
