The FEIN Starlock Plus set consists of 6 different E-Cut saw blades with bi-metal teeth in a practical plastic storage box at a special price. Contents: one each E-Cut Universal saw blades, 28mm and 44mm wide and 2 each E-Cut Long-Life saw blades 35mm and 65mm in wide. Supplied with a FEIN case.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the blade tip. No more wasted power means faster working, minimised vibration and better results. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
Compatible with all FEIN Oscillating Multi-Tools including FEIN AFMT 12 SL, FEIN AFMT 12 QSL, FEIN AFMM 18 QSL, FEIN FMT 250, FEIN FMM 350 Q, FEIN MultiMaster, FEIN MultiTalent. Also compatible with some Bosch Oscillating Multi-Tools including: Bosch GOP 280, Bosch GOP 350, Bosch GOP 300, Bosch GOP 250, Bosch GOP 18 V, Bosch PMF 350 CES and Bosch PMF 220 CE. Other brands will require an adapter from the machine’s manufacturer.
