Cut steel up to 1mm, plastic, fibreglass and soft materials
Segmented shape for cutting into corners
Ø 85mm diameter, high speed steel (HSS)
Starlock mounting for fast work progress and precise results
Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adapter
This 80mm diameter, high speed steel (HSS) blade will cut wood, non-ferrous metals, steel up to 1mm, plastic, fibreglass and soft materials. The segmented shape allows it to cut right into corners such as when removing putty from a rebated glazed frame. FEIN reference 106. Ø 85mm diameter.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the blade tip. No more wasted power, means faster working, minimised vibration and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
