Festool 90 Degree Guide Rail Edge Square FS-WA/90
- Make precise 90° cuts every time
- CNC machined anodised aluminium for accuracy and durability
- Quick lever clamp, attaches to guide rail in seconds
- Highly accurate cutting of sheet material
- Long contact surface for easy aligning with all edges
- Completely self-aligning, no adjustment necessary
Guaranteed, precise 90° alignment every time you use the Festool FS-WA/90 attached to a Festool guide rail. CNC machined from a single piece of aluminium and fitted with a quick action locking clamp makes it impossible to cut at anything other than exactly 90°. Used in combination with a circular saw, the FS-WA/90 and guide rail become a highly accurate mobile panel saw. Slide the square into the T-slot of your guide rail and close the latch; setup is as simple as that.
The FS-WA/90 features a long contact edge for positive alignment on a front or rear reference edge depending on the situation.
Grooves on the underside enable you to attach guide rail clamps for extra security.
EAN Barcode | 4014549363683 |
Model | FS-WA/90 |
