Festool Antistatic Suction Hose With RFID Chip D36 x 3.5m-AS/CTR
- Smooth and supple, no ribs to catch
- CLEANTEC connector for secure connection to power tool
- Smooth internal bore for increased airflow
- RFID chip for automatic suction hose detection
- Antistatic and lightweight, increases efficiency
- Tool connector locates into opposite end for storage or transport
- Fits Festool CT extractors, not suitable for extractors with Autoclean function
The robust, smooth outer casing makes all the difference compared to standard corrugated hoses, which catch on every corner. In addition to being antistatic, it minimises the possibility of damage to delicate work surfaces. The hose itself is light and extremely flexible offering maximum freedom of movement. The smooth internal bore reduces friction and increases the airflow rate. This major improvement increases efficiency and ensures better suction performance.
The CLEANTEC connector makes a quick and secure connection between the hose and power tool. The fitting conveniently fits into the opposite end for storage and transport, keeping any remaining dust in the hose. This feature also allows you to join two or more hoses for extended reach.
The hose features an RFID chip, which communicates the hose diameter on connection to a compatible extractor in order to ensure correct suction adjustments.
Suitable for Festool CT extractors, not suitable for extractors with Autoclean function.
