Festool CENTROTEC HSS Twist Drill Bit & Bit Holder
AX849493
AX849493
- Complete drill bit & bit holder with CENTROTEC fitting
- HSS for drilling wood, plastic and non-ferrous metal
- Supplied with two replacement drill bits, 4 sizes available.
Festool CENTROTEC Long Screwdriver Pozidrive BitsFrom £20.78 £17.32
Festool CENTROTEC Countersink with Depth Stop - 3.5mm DrillFrom £70.58 £58.82
FISCH Hex Drive Countersink - 2.4mm Drill No.6 ScrewSpecial Price £7.98 £6.65 was £10.58 £8.82 Save £2.60 £2.17
Show more
Show less
These HSS spiral drills have a CENTROTEC bit holder which is suitable for use in all CENTROTEC quick change chucks or a standard drill chuck. The high-speed steel drill bit is suitable for drilling wood, plastic and non-ferrous metals. Supplied with CENTROTEC holder and 2 drill bits which are easy to interchange with a hex key. Available in 4 sizes; 3mm, 3.5mm, 4mm or 5mm.
