Festool Diamond Discs for RENOFIX RG 130 Diamond Grinder
102418
From £235.98 £196.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Red – Abrasive: for resurfacing green concrete, sandstone, soft plaster etc., grinding cement screed for a smooth finish. Removing adhesive on screed, sand-lime bricks and aerated concrete.
When fitted to the Festool RG 130-E these diamond discs rapidly remove material from a wide variety of hard surfaces. The discs are 130mm in diameter, the diamond impregnated segments work in much the same way as a diamond cutting disc; in this case working on the flat effectively grinding the surface away.
