Festool ROTEX RO 90 DX FEQ-Plus Sander
- Truly universal sander with unique features and benefits
- ROTEX action, aggressive or fine sanding and polishing
- Jetstream principle, clears dust from working pad and pad stays cooler
- Pad made from MPE high tear resistant durable material
- FASTFIX quick accessory change
- Supplied with 90mm soft pad, Delta pad, disc protector
- Systainer T-LOC, SYS2 storage case
A truly universal sander from Festool, having several unique features and able to access areas other sanders just can't reach making it the perfect machine for many jobs. Able to take a range of 90mm diameter or Delta pad base which can be changed in seconds via the Festool FASTFIX system, compact in size and low in weight, it is so easy to handle and will give a perfect finish.
The two main secrets to this sander are the ROTEX action and JETSTREAM pad, ROTEX allows the machine to be either an aggressive or fine sander as well as a polisher. Just flick the switch and you can choose between a rotary / eccentric action for coarse sanding and polishing that will keep the surface temperature low or an eccentric action only for fine sanding. The JETSTREAM principle ensures the abrasive can work very efficiently and extends its life ensuring dust is drawn away from the sanding surface stopping accumulation. It in turn also reduces heat at the pad surface, another real bonus, as heat causes dust particles to clump together and block the abrasive. Polishing also benefits from a cooler pad. A range of accessories is available to suit all sanding and polishing needs.
Supplied with in a Systainer T-LOC case with 90mm Soft sanding pad, Delta sanding pad, and disc protector.
