Festool Rubin 2 Sanding Discs 150mm (48 Hole)
From £11.28 £9.40
  5. Half Star
11 Reviews
  • High-performance aluminium oxide abrasive for wood
  • Final sanding for varnishing, preparatory sanding for oiling or waxing
  • 48-hole Multi-Jetstream2 pad with Stickfix system
  • Enhanced extraction when used with and extractor
  • Helps achieve consistent smooth surface finish
  • 150mm diameter
  • Supplied in packs of 10
The 48-hole pattern of these Festool abrasive discs, when used with the matching Jetstream 2 pad and an extractor, results in virtually 100% dust extraction. The design even picks up dust attempting to escape from around the edge of the disc. The 48-hole design is fully compatible with the older 16-hole configuration.
Rubin 2 is a high quality aluminium oxide abrasive designed for use on bare wood and wooden products. It is ideal for sanding prior to painting, oiling or finishing furniture. Rubin 2 offers a faster finish; it quickly sheds wood fibres eliminating clogging so the abrasive stays sharp, leading to a greatly increased removal rate. Rubin 2 saves you money, the abrasive lasts longer and achieves consistent, high quality results in the least amount of time.
4.70 11
