Festool S 75/4 FSG/5 Jigsaw Blades Extra Stable Wood Cuts (Pkt 5)
- Extra stable blade, particularly well suited for straight cuts when using the guide rail
- For cuts in softwood/ hardwood, untreated chipboard, coated chipboard & veneered blockboard
- Cross-set teeth, conically ground for quick cuts in exact angles
- Blade length 75mm, Max cutting depth 55mm
- Supplied as pack of 5
Bosch T111C Jigsaw Blades Wood CuttingFrom £3.68 £3.07
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)Special Price £12.38 £10.32 was £13.68 £11.40 Save £1.30 £1.08
Extra stable blade, particularly well suited for straight cuts when using the guide rail . Suitable for softwood/ hardwood, untreated chipboard, coated chipboard and veneered blockboard. Cross-set teeth, conically ground for quick cuts in exact angles. Supplied in pack of 5.
Blade Type | HSS, Ground |
EAN Barcode | 4014549189344 |
Jigsaw Blade Length | 75 mm |
Jigsaw Blade Type | Straight Cuts |
Manufacturer Part Number | 499476 |
Max Cutting Depth | 55 mm |
Model | S 75/4 FSG/5 |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 4.23 mm \ 6 tpi |
